Motory FIAT DOHC 8V - aneb všechno co o ních víme.
Štěpán
Pro ty jenž umějí anglicky.
ps: Je tám vesměs to samé, co na začátku tématu.
GENERAL SPECIFICATIONS:
________________________________________
AC (1967-1969)
Body Frame -- Unitized body construction, front engine rear drive.
Engine -- Type 124AC.000. Water-cooled in-line four cylinder. Cast iron block. Aluminum cylinder head. Twin overhead camshaft with cogged timing belt and two valves per cylinder. Weber twin-barrel carburetor.
Displacement -- 1,438cc (87.75 cu. in.)
Bore & stroke -- 80mm x 71.5mm
Compression ratio -- 8.9 to 1
Horsepower -- 96 hp at 6500 rpm
Torque -- 82.42 ft. lbs. at 4000 rpm
Transmission -- Four speeds forward (1967-68), Five speeds forward (1969) plus reverse. Fully synchromeshed in all forward gears.
Front Suspension -- Wishbone control arms. Coil springs, hydraulic shock absorbers and anti-roll bar.
Rear Suspension -- Rigid axle anchored by two trailing arms and transverse rod, coil springs with hydraulic shock absorbers and anti-roll bar.
Steering -- Worm and roller gear. Turning radius 36' 1"
Brakes -- Four wheel disc brakes with power assist. Mechanical parking brake. Wheels and tires -- 5" x 13" steel wheels with 165 x 13 in. radial ply tires (alloys optional)
Electrical -- 12-volt 700-Watt alternator.
Fuel Tank -- 11.8 gals.
BC (1969-1972)
All specs and equipment as "AC" unless noted below:
Engine -- Type 125AC.040.
Displacement -- 1,608cc (96.48 cu. in.)
Bore & stroke -- 80mm x 80mm
Compression ratio--8.5:1
Horsepower -- 104 hp at 6000 rpm
Torque -- 94 ft. lbs. at 4200 rpm
Transmission -- Five speeds forward plus reverse. Fully synchromeshed in all forward gears.
Rear Suspension -- Rigid axle anchored by two trailing arms and transverse rod, coil springs with hydraulic shock absorbers.
CC (1973-1975)
All specs and equipment as "AC" and "BC" unless noted below:
Engine -- Type 132AC.000.
Displacement -- 1,592cc
Bore & stroke -- 80mm x 79.2mm
Compression ratio -- 8.0 to 1
Horsepower -- 87 hp at 6000 rpm
Torque -- 96 ft. lbs. at 4200 rpm
Engine -- Type 132AC1.000.
Displacement -- 1756cc
Bore & stroke -- 84mm x 80mm
Horsepower -- 92.5 hp at 6200 rpm
Torque -- 92 ft. lbs. at 3000 rpm
PERFORMANCE: The performance figures listed below are actually averages compiled from magazine acceleration and braking tests of US models.
Series 0-60 mph ¼ mile Top Speed Braking 'D' from 60 mph
AC 10.8 sec 18.6 s@ 74 mph 104 mph 161 ft
BC 10.5 sec 107 mph 164 ft
CC 10.2 sec 107 mph 165 ft
PHYSICAL DIMENSIONS:
Parameter
AC BC CC
Length (in) 162 165 167-171
Width (in) 65.8 65.8 65.8
Height (in) 52.8 52.8 52.8
Wheelbase (in) 95.3 95.3 95.3
Track (in) 53.0/51.8 53.0/51.8 53.0/51.8
Clearance (in) 4.7 4.9 4.9
Curb Weight (lbs) 2110 2214 2205-2360
Distribution F/R % 54/46 53/47 53/47
AC (1967-1969)
BC (1969-1972)
CC (1973-1975)
Parameter
AC BC CC
Štěpán
To Vašek nebo pro kohokoliv, kdo by to mohl vědět.
Jakej je předstih na FIATu DOHC 1608cm3 ?
Nechci tady filozofovat o tom, že by to mohlo být podobný, jako na ladě 5 - 7° ! Chci pouze přesnou odpověď.
Včera jsem totiž připojil k tomu strobáč, a světe div se
!!! Jestli mu mám věřit, tak mi motor nejklidnějc pracuje s předstihem 45° ( při 2000 rpm ) . Absolutní blbost. Když dám víc tak se klepe! Když dám míň, tak taky.
Takže Babo raď!!!
Takže Babo raď!!!
- Roman
V knihe Technicke a nastavovacie udaje motorovych vozidiel som nasiel dva fiaty 125 s motorom 1608ccm, ale neviem ci ten silnejsi 125 special je dohc. Ma vykon 73,5kW/62000t, oznacenie motora 125B.000, ale typ rozvodu prave u tychto fiatov nie je uvedeny. Ale zakladny predstih je tam 10 stupnov.
- VaSek
Ahoj,
zakladni (staticky) predstih 10st. Otackova regulace ma rozsah 28st. Podtlakova 15st. Ve 2000ot snad nemuzes nastavovat predstih? Graf regulaci nemam takze nevim kolik ma byt ve 2000ot.
S pozdravem
Štěpán
Roman píše:V knihe Technicke a nastavovacie udaje motorovych vozidiel som nasiel dva fiaty 125 s motorom 1608ccm, ale neviem ci ten silnejsi 125 special je dohc. Ma vykon 73,5kW/62000t, oznacenie motora 125B.000, ale typ rozvodu prave u tychto fiatov nie je uvedeny. Ale zakladny predstih je tam 10 stupnov.
Mám ten silnější 73,5 kW.
[shadow=red] DĚKUJÍ KUCÍ
Štěpán
Na volnoběhu jsem měl o něco míň než těch 45° ! A i těch 45 je jen tak pro orientaci!VaSek píše:Ahoj,
Prostě mě překvapilo, že jsem měl značku na řemenici skoro svisle vzhůru
Jo a žádnej podtlak tam nemam. Dokonce tam ani není oktankorektor.
- Roman
Len na upresnenie, podla http://www.zuckerfabrik24.de/fiat/fiatdaten_pb50.htm je motor 125B.000 DOHC, takze ten zakladny predstih by mal sediet.
Štěpán
Štěpán
Podla mojej chytrej knizky tam ma byt karbec Weber 34 DCHE 20 a jeho hladina ma byt 8,5mm.Štěpán Getsko píše:Romane mohl bych tě ještě prosím pořádat, jestli bys v té své chytré knížce nenašel hladinu v plovákový komoře!!! Je to Weber 2x34 . Mám to seřízený podle oka, a jak sám dobře víš, je to na nic.
Předem děkují.
Štěpán
Myso a měří se ta hladina stejně jako na ladach jako vzdálenost plováku od horního dílu karbu nebo nějak jinak?Myso píše:Podla mojej chytrej knizky tam ma byt karbec Weber 34 DCHE 20 a jeho hladina ma byt 8,5mm.Štěpán Getsko píše:Romane mohl bych tě ještě prosím pořádat, jestli bys v té své chytré knížce nenašel hladinu v plovákový komoře!!! Je to Weber 2x34 . Mám to seřízený podle oka, a jak sám dobře víš, je to na nic.
Předem děkují.
ps: Díky!
