Motory FIAT DOHC 8V - aneb všechno co o ních víme.
Moderator: Moderátoři
Štěpán
Pro ty jenž umějí anglicky.
ps: Je tám vesměs to samé, co na začátku tématu.
GENERAL SPECIFICATIONS:
________________________________________
AC (1967-1969)
Body Frame -- Unitized body construction, front engine rear drive.
Engine -- Type 124AC.000. Water-cooled in-line four cylinder. Cast iron block. Aluminum cylinder head. Twin overhead camshaft with cogged timing belt and two valves per cylinder. Weber twin-barrel carburetor.
Displacement -- 1,438cc (87.75 cu. in.)
Bore & stroke -- 80mm x 71.5mm
Compression ratio -- 8.9 to 1
Horsepower -- 96 hp at 6500 rpm
Torque -- 82.42 ft. lbs. at 4000 rpm
Transmission -- Four speeds forward (1967-68), Five speeds forward (1969) plus reverse. Fully synchromeshed in all forward gears.
Front Suspension -- Wishbone control arms. Coil springs, hydraulic shock absorbers and anti-roll bar.
Rear Suspension -- Rigid axle anchored by two trailing arms and transverse rod, coil springs with hydraulic shock absorbers and anti-roll bar.
Steering -- Worm and roller gear. Turning radius 36' 1"
Brakes -- Four wheel disc brakes with power assist. Mechanical parking brake. Wheels and tires -- 5" x 13" steel wheels with 165 x 13 in. radial ply tires (alloys optional)
Electrical -- 12-volt 700-Watt alternator.
Fuel Tank -- 11.8 gals.
BC (1969-1972)
All specs and equipment as "AC" unless noted below:
Engine -- Type 125AC.040.
Displacement -- 1,608cc (96.48 cu. in.)
Bore & stroke -- 80mm x 80mm
Compression ratio--8.5:1
Horsepower -- 104 hp at 6000 rpm
Torque -- 94 ft. lbs. at 4200 rpm
Transmission -- Five speeds forward plus reverse. Fully synchromeshed in all forward gears.
Rear Suspension -- Rigid axle anchored by two trailing arms and transverse rod, coil springs with hydraulic shock absorbers.
CC (1973-1975)
All specs and equipment as "AC" and "BC" unless noted below:
Engine -- Type 132AC.000.
Displacement -- 1,592cc
Bore & stroke -- 80mm x 79.2mm
Compression ratio -- 8.0 to 1
Horsepower -- 87 hp at 6000 rpm
Torque -- 96 ft. lbs. at 4200 rpm
Engine -- Type 132AC1.000.
Displacement -- 1756cc
Bore & stroke -- 84mm x 80mm
Horsepower -- 92.5 hp at 6200 rpm
Torque -- 92 ft. lbs. at 3000 rpm
PERFORMANCE: The performance figures listed below are actually averages compiled from magazine acceleration and braking tests of US models.
Series 0-60 mph ¼ mile Top Speed Braking 'D' from 60 mph
AC 10.8 sec 18.6 s@ 74 mph 104 mph 161 ft
BC 10.5 sec 107 mph 164 ft
CC 10.2 sec 107 mph 165 ft
PHYSICAL DIMENSIONS:
Parameter
AC BC CC
Length (in) 162 165 167-171
Width (in) 65.8 65.8 65.8
Height (in) 52.8 52.8 52.8
Wheelbase (in) 95.3 95.3 95.3
Track (in) 53.0/51.8 53.0/51.8 53.0/51.8
Clearance (in) 4.7 4.9 4.9
Curb Weight (lbs) 2110 2214 2205-2360
Distribution F/R % 54/46 53/47 53/47
AC (1967-1969)
BC (1969-1972)
CC (1973-1975)
Parameter
AC BC CC
Štěpán
To Vašek nebo pro kohokoliv, kdo by to mohl vědět.
Jakej je předstih na FIATu DOHC 1608cm3 ?
Nechci tady filozofovat o tom, že by to mohlo být podobný, jako na ladě 5 - 7° ! Chci pouze přesnou odpověď.
Včera jsem totiž připojil k tomu strobáč, a světe div se
!!! Jestli mu mám věřit, tak mi motor nejklidnějc pracuje s předstihem 45° ( při 2000 rpm ) . Absolutní blbost. Když dám víc tak se klepe! Když dám míň, tak taky.
Takže Babo raď!!!
Takže Babo raď!!!
V knihe Technicke a nastavovacie udaje motorovych vozidiel som nasiel dva fiaty 125 s motorom 1608ccm, ale neviem ci ten silnejsi 125 special je dohc. Ma vykon 73,5kW/62000t, oznacenie motora 125B.000, ale typ rozvodu prave u tychto fiatov nie je uvedeny. Ale zakladny predstih je tam 10 stupnov.
Roman
Ahoj,
zakladni (staticky) predstih 10st. Otackova regulace ma rozsah 28st. Podtlakova 15st. Ve 2000ot snad nemuzes nastavovat predstih? Graf regulaci nemam takze nevim kolik ma byt ve 2000ot.
S pozdravem
VaSek (ex Vaz 2107,ex Fiat Bravo GT, Fiat 124 Spider, Fiat Coupé 2.0 16VT, Subaru Outback 3.0 H6)
Štěpán
Roman wrote:V knihe Technicke a nastavovacie udaje motorovych vozidiel som nasiel dva fiaty 125 s motorom 1608ccm, ale neviem ci ten silnejsi 125 special je dohc. Ma vykon 73,5kW/62000t, oznacenie motora 125B.000, ale typ rozvodu prave u tychto fiatov nie je uvedeny. Ale zakladny predstih je tam 10 stupnov.
Mám ten silnější 73,5 kW.
[shadow=red] DĚKUJÍ KUCÍ
Štěpán
Na volnoběhu jsem měl o něco míň než těch 45° ! A i těch 45 je jen tak pro orientaci!VaSek wrote:Ahoj,
Prostě mě překvapilo, že jsem měl značku na řemenici skoro svisle vzhůru
Jo a žádnej podtlak tam nemam. Dokonce tam ani není oktankorektor.
Len na upresnenie, podla http://www.zuckerfabrik24.de/fiat/fiatdaten_pb50.htm je motor 125B.000 DOHC, takze ten zakladny predstih by mal sediet.
Roman
Štěpán
Štěpán
Podla mojej chytrej knizky tam ma byt karbec Weber 34 DCHE 20 a jeho hladina ma byt 8,5mm.Štěpán Getsko wrote:Romane mohl bych tě ještě prosím pořádat, jestli bys v té své chytré knížce nenašel hladinu v plovákový komoře!!! Je to Weber 2x34 . Mám to seřízený podle oka, a jak sám dobře víš, je to na nic.
Předem děkují.
_________________
_________________
Štěpán
Myso a měří se ta hladina stejně jako na ladach jako vzdálenost plováku od horního dílu karbu nebo nějak jinak?Myso wrote:Podla mojej chytrej knizky tam ma byt karbec Weber 34 DCHE 20 a jeho hladina ma byt 8,5mm.Štěpán Getsko wrote:Romane mohl bych tě ještě prosím pořádat, jestli bys v té své chytré knížce nenašel hladinu v plovákový komoře!!! Je to Weber 2x34 . Mám to seřízený podle oka, a jak sám dobře víš, je to na nic.
Předem děkují.
ps: Díky!
