How add torbo?
Hmm first step is find the way to connect turbo with engine. I made this:
Its feet to stock manifold.
My next turbo will be on shorter pipe.
Ofcourse accu must find another place to live
Next is downpipe:
And this can be end of exhaust
Find the way to connect oil return ilne to oil sump. It must be over the oil level in sump.
Buy y-pipe from ladas with oil pressure gauage and find way to connest this with turbo
Put on this big diameter fuel line. Propably it will leak after 5kkm but who cares.
Fabricate this:
Make sure the flange to pipe connection is good quality and the flange is perfectly flat. Like mirror!
Find the way to connect cold part of turbo with engine.
Use intercooler and blowoff valve to higher performance and durability of system.
The hardest part - fuel. As i said i using lpg gas. Conwersion is simple - you must add compensation like this:
Important thing is that the compensation is must be on the first and second level(on two sides) of this lpg thing
And this also must be done:
Make the second throttle valwe to open mechanical not vaccum. In other case it will be close with turbo pressure.
And thats it. Good luck with turbo
(sorry for my english
Check this polish project: samara turbo
