Servisny Manualy na 2121 Lada NIVA
Michael 4x4
Příspěvek od Michael 4x4 »
v angličtine , formát pdf, otvoríte napr. cez Adobe Acrobat
Kód: Vybrat vše
http://www.edisk.cz/stahni/73166/1700_1.pdf_4.11MB.html
http://www.edisk.cz/stahni/45580/1700_2.pdf_5.14MB.html
http://www.edisk.cz/stahni/82760/1700_3.pdf_4.7MB.html
Je to na 1.7 MPi, SPi a 1.9 Diesel (a 1.7 karburator :roll: )
možno to niekomu pomôže
Zhruba toto tam je:
Section 1. General data ..........................................................4
Section 2. Engine ..................................................................7
Engine - removal and refitting..........................................12
Cylinder block ..................................................................19
Inspection and repair..................................................19
Pistons and connecting rods ...........................................21
Selecting piston to cylinder ........................................23
Dismantling and reassembly ......................................23
Crankshaft and flywheel ..................................................24
Design description......................................................24
Inspection and overhaul .............................................24
Cylinder head and valve gear..........................................26
General description ....................................................26
Valve clearance adjustment .......................................27
Cylinder head - removal and refitting .........................28
Cylinder head - dismantling and reassembly............28
Camshaft and timing gear ...............................................32
Cooling system ...............................................................34
Lubrication system...........................................................38
Fuel system .....................................................................42
Carburettor.......................................................................46
Exhaust gas recirculation system ....................................55
Exhaust system ...............................................................46
Chapter 3. Power train.........................................................57
Clutch ..............................................................................57
Gearbox...........................................................................64
Transfer box ....................................................................73
Drive line .........................................................................80
Rear axle .........................................................................84
Front axle ........................................................................96
Chapter 4. Wheel suspensions ...........................................100
Front suspension...........................................................102
Rear suspension............................................................110
Chapter 5. Steering ...........................................................115
Steering - inspection, check and adjustment ................116
Steering mechanism......................................................118
Chapter 6 Braking system..................................................121
Front brakes ..................................................................128
Rear brakes...................................................................130
Handbrake.....................................................................134
‘hapter 7. Electrical system...............................................135
Wiring and fuses ...........................................................135
Battery ...........................................................................136
Alternator.......................................................................140
Starter motor .................................................................146
Ignition system ..............................................................149
Lighting and signalling...................................................156
Windscreen wiper/washer .............................................159
Instruments....................................................................163
Chapter 8. Bodywork.........................................................167
Bodywork - repair .........................................................169
Paintwork.......................................................................172
Door...............................................................................176
Bonnet, bumpers...........................................................179
Bodywork glazing and windscreen washers .................180
Instrument panel, seats.................................................181
Heater unit.....................................................................183
Chapter 9.
VAZ-21213 vehicle modifications, alternative and additional
equipment...............................................................185
VAZ-21214 vehicle ........................................................185
Engine repair - description ............................................185
Central Injection Unit.....................................................186
VAZ-21214-20 vehicle ...................................................189
Engine 21214-10...........................................................190
VAZ-21215-10 vehicle ...................................................197
Cooling system..............................................................200
Lubrication system ........................................................202
Fuel system ...................................................................202
Exhaust emission system..............................................203
Electrical system ...........................................................203
Steering with BREED «SRS-40»
driver’s airbag in the steering wheel ............................209
Attachments.....................................................................212
alena25
Příspěvek od alena25 »
komplet servisný manual v češtine Lada niva 1.6 som si stiahol
na
www.ladaklub.com
v sekcii knihovna
avšak teraz ma tam nechce pustiť aj keď som riadne registrovaný
:roll:
rezna
Příspěvek od rezna »
manual na 1.7i jsem tu nekde postoval uz nekolikrat a me samotnemu tu byl postnut - striekacka.pdf -> hledat
jiri.k
Příspěvek od jiri.k »
druha cast toho anglickeho manualu se nejak defektne zobrazuje. skoda.
black13
Příspěvek od black13 »
nemal by niekto v el. forme manual na 21214 v cz alebo sk?
dakujem za info
Komunar
Odborný návod pro opravy vozů LADA NIVA nejen pro Rusofily
Příspěvek od Komunar »
O elektrice vím že kope a není vidět.
Bzuco 4x4
Schema na Lady (Katalogy ND)
Příspěvek od Bzuco 4x4 »
Nie je to sice manual,ale mozno posluzi
http://www.lada-auto.sk/?menuID=nd-0&catID=nd-2
Naposledy upravil(a) Bzuco 4x4 dne sob čer 12, 2010 08:34, celkem upraveno 2 x.
RIKIJAN
Příspěvek od RIKIJAN »
http://translate.google.com/translate?j ... l=ru&tl=cs
v českem překladu
:roll:
Neposílej dvojpříspěvky, na úpravy tu máme tlačítko Upravit ;)
Naposledy upravil(a) RIKIJAN dne stř črc 14, 2010 22:54, celkem upraveno 1 x.
matko77
Manuál na Nivu
Příspěvek od matko77 »
Ahojte,
nikde som nenasiel manula na Nivu 2121 - 1,6 r.v. 1960.
Ma niekto prosim nieco take?
Potreboval by som opravit zadny kardan a chcem zablokovat zadny diferencial, lebo na nej jazdim iba do kopca a iba po lesnej ceste.
Dakujem za odpoved :)
[ Komentář přidal: Laďuša: po leden 17, 2011 21:48 ]
Pro příště aspoň umístit do správný sekce!
Viku, jestli tady už někde něco takovýho je, kdyžtak to sluč ;)
Naposledy upravil(a) matko77 dne pon led 17, 2011 21:48, celkem upraveno 1 x.
http://www.autoprospect.ru/vaz/21213-ni ... masla.html
Ovšem v roce 1960 se Nivy nedělaly...
Pančocha
Re: Manuál na Nivu
Příspěvek od Pančocha »
Zdarec
Mám pocit že to nebude řídit a značná část výkonu půjde do prachu, ale možná se pletu.
Naprosto zbytečná práce, Niva projede všude.
jiri.k
Re: Manuál na Nivu
to asi jezdis jako masinka po kolejich- rovne tam a rovne zpatky... :P
sup7sup7
Manuál na NIVU 1.7i, 1999
Příspěvek od sup7sup7 »
ahoj, máte tu někdo tušení kde se dá stáhnout kompletní manuál na NIVU 1.7i, mam rok 1999. Nebo ho někdo máte?
Rozdíly jsou asi jen v motorech ( a k tomu příslušná elekrtika a palivový sistém) jinak je to lautr to samý od doby co se začli Nivy vyrábět, že? Pokud možno v češtine.
ideálně formát *.pdf
díky moc.
Kalcak
opravy a udrzba
Příspěvek od Kalcak »
Dobry den
poridil jsem si ladu nivu, sehnal nijakou literaturu od Tůmi ale je to moc vseobecne
potraboval bych jen na nivu je takoveho neco k dostani?
Michael 4x4
Re: opravy a udrzba
Potrebuješ to nutne v knižnej papierovej podobe? Na nete, aj tu na fóre je toho kopec, návody, schémy, obrázky montáže....
O knihách okrem Tumy viem len o týchto :arrow: http://www.lada-auto.sk/?menuID=nd-0&catID=nd-4
Zpět na „Manuály a schémata“
